<?xml version="1.0" encoding="utf-8"?>
<feed xml:lang="en" xmlns="http://www.w3.org/2005/Atom"><title>Recent posts to Problems using MySql Library and SysProcessExecuteCommand2 together</title><link href="https://forge.codesys.com/forge/talk/Engineering/thread/3420046d08/" rel="alternate"/><link href="https://forge.codesys.com/forge/talk/Engineering/thread/3420046d08/feed.atom" rel="self"/><id>https://forge.codesys.com/forge/talk/Engineering/thread/3420046d08/</id><updated>2024-06-18T00:50:26.680000Z</updated><subtitle>Recent posts to Problems using MySql Library and SysProcessExecuteCommand2 together</subtitle><entry><title>Problems using MySql Library and SysProcessExecuteCommand2 together</title><link href="https://forge.codesys.com/forge/talk/Engineering/thread/3420046d08/?limit=25#875a" rel="alternate"/><published>2024-06-18T00:50:26.680000Z</published><updated>2024-06-18T00:50:26.680000Z</updated><author><name>kazuhiro</name><uri>https://forge.codesys.com/u/kazuhiro/</uri></author><id>https://forge.codesys.com097437f4cc6bbd0e34e1a23aad7d94eed4912214</id><summary type="html">&lt;div class="markdown_content"&gt;&lt;p&gt;I use fbMsSQL_compact(FUN) of the MySQL Library to write data to the database. There is no problem when writing data using only fbMsSQL_compact(FUN). However, when I try to write data obtained using SysProcessExecuteCommand2 to the database using fbMsSQL_compact(FUN), an error message "Dest server on ip address:xxx.xxx.xxx.xxx and port:1433 is unreachable" appears and writing is not possible. From what I have researched, it seems that writing is not completed in one cycle of fbMsSQL_compact(FUN), and when SysProcessExecuteCommand2 is executed first in the second cycle, the work done in one cycle of fbMsSQL_compact(FUN) is reset. Could you please give me some advice?&lt;/p&gt;&lt;/div&gt;</summary></entry></feed>
