<?xml version="1.0" encoding="utf-8"?>
<feed xml:lang="en" xmlns="http://www.w3.org/2005/Atom"><title>Recent posts to Does G75 work when SMC_NCInterpreter is used?</title><link href="https://forge.codesys.com/forge/talk/Engineering/thread/93045e88df/" rel="alternate"/><link href="https://forge.codesys.com/forge/talk/Engineering/thread/93045e88df/feed.atom" rel="self"/><id>https://forge.codesys.com/forge/talk/Engineering/thread/93045e88df/</id><updated>2025-05-09T07:29:50.944000Z</updated><subtitle>Recent posts to Does G75 work when SMC_NCInterpreter is used?</subtitle><entry><title>Does G75 work when SMC_NCInterpreter is used?</title><link href="https://forge.codesys.com/forge/talk/Engineering/thread/93045e88df/?limit=25#4fa2" rel="alternate"/><published>2025-05-09T07:29:50.944000Z</published><updated>2025-05-09T07:29:50.944000Z</updated><author><name>sercan</name><uri>https://forge.codesys.com/u/sercan/</uri></author><id>https://forge.codesys.com3d765ea317b2fab01caeb4b1a9a746b8a7f31828</id><summary type="html">&lt;div class="markdown_content"&gt;&lt;p&gt;When a G75 command is received in a SoftMotion+CNC project, SMC_NCInterpreter does not generate any error commands, but the command does not continue execution!&lt;/p&gt;
&lt;p&gt;There is information about SMC_NCDecoder in the documentation of the G75 command.&lt;/p&gt;
&lt;p&gt;Is this command only supported by SMC_NCDecoder?&lt;/p&gt;
&lt;p&gt;Can the G75 command be used with SMC_NCInterpreter?&lt;/p&gt;
&lt;p&gt;Forexample:&lt;/p&gt;
&lt;div class="codehilite"&gt;&lt;pre&gt;&lt;span&gt;&lt;/span&gt;&lt;code&gt;G75                                                    ; RUNNING
G01 X$Settings.X$ Y$Settings.Y$ Z$Settings.Z$          ; -
G75                                                    ; -
G01 X100.0 Y200.0 Z300.0                               ; -
&lt;/code&gt;&lt;/pre&gt;&lt;/div&gt;
&lt;/div&gt;</summary></entry></feed>
