PWM_mod:
wollvieh
2022-03-21
2022-05-17
  • wollvieh
    wollvieh - 2022-03-21
    {warning disable C0351}
    function block for raspberry Adafruit PWM board
    1) to use this function block install in the device-repository the "500_0000 0004_4.4.0.1.devdesc.xml"
    2) install in the library repository the "Raspberry I2C AdafruitPWM_mod.library"
    depending on bool variable "_xUseLimitsForRCServo" there are 2 modes existent :
    _xUseLimitsForRCServo := TRUE : in this mode the fb is used for controlling of RC servos , frequency 50Hz, DC = 1..2ms On
    _xUseLimitsForRCServo := FALSE : in this mode the fb is used for controlling free PWM mode
    uisetfrequency possible from 1 upto 1000Hz, DC possible from 0..100 (%)
    Sample GVL List :
    VAR_GLOBAL
    x_0FreeMode_1ServoMode : BOOL := TRUE; // RC Servo Mode is selected
    uiSetFrequency : UINT := 50; // frequency 50 Hz
    MAXPWM_RCMODE : LREAL := 2.0; // max DC = 2.0 ms
    MINPWM_RCMODE : LREAL := 1.0; // min DC = 1.0 ms
    lr_SetpointCannel_0 : LREAL := 1.5; // setpoint 0 default = 1.0 ms
    lr_SetpointCannel_1 : LREAL := 1.5; // setpoint 1 default = 1.0 ms
    lr_SetpointCannel_2 : LREAL := 1.5; // setpoint 2 default = 1.0 ms
    lr_SetpointCannel_3 : LREAL := 1.5; // setpoint 3 default = 1.0 ms
    Sample Program block :
    // Settings for the fb
    Adafruit_PWM_mod._freq := uiSetFrequency; // setpoint frequency
    Adafruit_PWM_mod._xUseLimitsForRCServo := x_0FreeMode_1ServoMode; // select RC Servo Mode
    Adafruit_PWM_mod.axEnable[0] := TRUE; // enable channel 0
    Adafruit_PWM_mod.axEnable[1] := TRUE; // enable channel 1
    Adafruit_PWM_mod.axEnable[2] := TRUE; // enable channel 2
    Adafruit_PWM_mod.axEnable[3] := TRUE; // enable channel 3
    Adafruit_PWM_mod._alrMin[0] := MINPWM_RCMODE; // minimal DC RC Mode
    Adafruit_PWM_mod._alrMin[1] := MINPWM_RCMODE; // minimal DC RC Mode
    Adafruit_PWM_mod._alrMin[2] := MINPWM_RCMODE; // minimal DC RC Mode
    Adafruit_PWM_mod._alrMin[3] := MINPWM_RCMODE; // minimal DC RC Mode
    Adafruit_PWM_mod._alrMax[0] := MAXPWM_RCMODE; // maximal DC RC Mode
    Adafruit_PWM_mod._alrMax[1] := MAXPWM_RCMODE; // maximal DC RC Mode
    Adafruit_PWM_mod._alrMax[2] := MAXPWM_RCMODE; // maximal DC RC Mode
    Adafruit_PWM_mod._alrMax[3] := MAXPWM_RCMODE; // maximal DC RC Mode
    // signal to output 0
    IF x_0FreeMode_1ServoMode = TRUE // RC servo mode or free mode ?
    THEN
    Adafruit_PWM_mod.alrPWM[0] := LIMIT(0.0,(lr_SetpointCannel_0/100.0),1.0); // alrPWM = 0.0..1.0 ms (added to _alrMin )
    ELSE
    Adafruit_PWM_mod.alrPWM[0] := lr_SetpointCannel_0; // alrPWM = 0..100% DC in free mode
    // signal to output 1
    THEN
    Adafruit_PWM_mod.alrPWM[1] := LIMIT(0.0,(lr_SetpointCannel_1/100.0),1.0); // alrPWM = 0.0..1.0 ms (added to _alrMin )
    ELSE
    Adafruit_PWM_mod.alrPWM[1] := lr_SetpointCannel_1; // alrPWM = 0..100% DC in free mode
    // signal to output 2
    THEN
    Adafruit_PWM_mod.alrPWM[2] := LIMIT(0.0,(lr_SetpointCannel_2/100.0),1.0); // alrPWM = 0.0..1.0 ms (added to _alrMin )
    ELSE
    Adafruit_PWM_mod.alrPWM[2] := lr_SetpointCannel_2; // alrPWM = 0..100% DC in free mode
    // signal to output 3
    THEN
    Adafruit_PWM_mod.alrPWM[3] := LIMIT(0.0,(lr_SetpointCannel_3/100.0),1.0); // alrPWM = 0.0..1.0 ms (added to _alrMin )
    ELSE
    Adafruit_PWM_mod.alrPWM[3] := lr_SetpointCannel_3; // alrPWM = 0..100% DC in free mode
    FUNCTION_BLOCK AdafruitPwm_mod EXTENDS i2c
    VAR_INPUT
    _xUseLimitsForRCServo : BOOL := TRUE;(
    True = RC Servo Mode, , FALSE = Free PWM Mode )
    _freq: UINT := 50; (
    frequency [Hz] )
    alrPWM : ARRAY[0..15] OF LREAL; (
    _alrMin.._alrMax = xms..yms Signal On in RC Servo Mode , 0..100 = 0..100% %DC in free PWM Mode )
    axEnable : ARRAY[0..15] OF BOOL := [4(TRUE)]; (
    Bit x = TRUE: set PWM output channel x; FALSE: do not modify output signal of channel x )
    _alrMin: ARRAY[0..15] OF LREAL := [16(0.7)]; (
    minimum time [ms], the pulse is ON for RC Servo Mode )
    _alrMax: ARRAY[0..15] OF LREAL := [16(2.2)]; (
    maximum time [ms], the pulse is ON for RC Servo Mode )
    VAR_OUTPUT
    no longer supported, use axEnable instead
    _usiUsedOutputs: USINT := 16; ( number of used outputs ) )
    _usiSMAxes: USINT := 0; (
    internal counter for registered SM axes )
    _rPeriod : LREAL; (
    Period [ms], time between two rising edges *)
    _alrOldPWM : ARRAY[0..15] OF LREAL;
    _lrOldFreq : LREAL;
    VAR_TEMP
    i, usi : USINT;
    Related
    Talk.ru: 1
    Talk.ru: 2
    Talk.ru: 3
    Last edit: wollvieh 2022-03-22
  • apod - 2022-05-17
    Thank you! Runs perfectly.
  • wollvieh
    wollvieh - 2022-05-17
    good to hear! Enjoy!
    @e.schwellinger : i've corrected the PWM frequency Faktor In the library ,and measured it with my Old (but gold) Hameg Osszilscope. Should
    be corrected in the 3s Sample lib.
