I have a pretty complex program, and everything was working fine using Codesys control x64, because of the requirements I moved to use RTE system, with 200Β΅s cycle time.
First I was developing everything just fine. but suddenly i start getting the Program loaded Exception, i when I get to look to the logger, I found only this.
Sound pretty obvious that I have a SysMem issue, but the question is, how can I restart it?
What I tried:
-restart pc with soft RTE.
-restart the RTE
-load an empty program
and the logger send me not a single info/warning/error/ or exception message.
Any idea how to address this issue?
Best Regards
Alebrije
I found a solution to this, in the application tap of the codesys RTE system configuration. The standard logger was disabled.
I also update the retain Type to *On Powerfall.
Everything is working now!
Hello:
What I tried:
-restart the RTE
Best Regards
Alebrije
Just to update this.
