Continuous Integration
CI / CD
CODESYS and Drone
Pipelines and Staging
For example:
  5. Deploy needs an FTP client
Build Artifacts
Download Links
Example Pipeline
  • Compile Libraries
  • Extract Library Source Code
  • Create Packages
  • Build Packages
kind: pipeline
workspace:
  base: /working
steps:
  - name: compile
    image: codesys-ide:local
    commands:
      - codesys compile-library
      - find -name \*.compiled-library -exec cp {} .drone-artifacts/ \;
