Continuous Integration
CI / CD
CODESYS and Drone
Pipelines and Staging
For example:
  5. Deploy needs an FTP client
Build Artifacts
Download Links
Example Pipeline
  • Compile Libraries
  • Extract Library Source Code
  • Create Packages
  • Build Packages
kind: pipeline
workspace:
  base: /working
steps:
  - name: compile
    image: codesys-ide:local
    commands:
      - codesys compile-library
      - find -name \*.compiled-library -exec cp {} .drone-artifacts/ \;
Trigger and build time
The build will be triggered whenever you commit something into your repository. But the exact time when the build is started might vary from time to time. Roughly it should be around 5 to 30 minutes after the commit.
