Continuous Integration
CI / CD
CODESYS and Drone
Pipelines and Staging
For example:
  5. Deploy needs an FTP client
Build Artifacts
Download Links
Example Pipeline
  • Compile Libraries
  • Extract Library Source Code
  • Create Packages
  • Build Packages
kind: pipeline
workspace:
  base: /working
steps:
  - name: compile
    image: codesys-ide:local
    commands:
      - codesys compile-library
All "codesys" commands are automatically collecting their outet as artifacts. So when you call compile-library, you will get all created *.compile-library files as build artifacts.
Adding own artifacts
If you want to save other files as build artifacts, you can simply add a copy command to your ".drone.yml".
kind: pipeline
workspace:
  base: /working
steps:
  - name: compile
    commands:
      - some command that creates some-file
      - cp some-file .drone-artifacts/
