Continuous Integration
CI / CD
CODESYS and Drone
Pipelines and Staging
For example:
  5. Deploy needs an FTP client
Build Artifacts
Download Links
Example Pipeline
  • Compile Libraries
  • Extract Library Source Code
  • Create Packages
  • Build Packages
kind: pipeline
workspace:
  base: /working
steps:
  - name: compile
    image: codesys-ide:local
    commands:
      - codesys compile-library
All "codesys" commands are automatically collecting their outet as artifacts. So when you call compile-library, you will get all created *.compile-library files as build artifacts.
Adding own artifacts
If you want to save other files as build artifacts, you can simply add a copy command to your ".drone.yml".
kind: pipeline
workspace:
  base: /working
steps:
  - name: compile
    commands:
      - some command that creates some-file
      - cp some-file .drone-artifacts/
Scenarios
Drone is build and test system, which in its nature is highly flexible. You can automate many different tasks with it.
Such as:
  • build compiled libs
  • build test applications
  • build bootapplications
  • build packages
All this can run automatically after every commit on CODESYS Forge. The only limit is actually the time it takes until a job is started, and the execution time of the job.
The free offer of the Drone CI/CD system limits the total execution time of a job to 5 minutes. This should be enough for all the above mentioned tasks, but it avoids that someone is ripping this service.
The time between the commit and the job being executed might vary, based on the load of the system. So there is no guarantee that the build jobs are running at a specific time.
Compile Libraries
kind: pipeline
workspace:
  base: /working/repo
steps:
  - name: compile
    commands:
In this example, we have a build pipeline with one step only. Every step defines its own stage, why I would recommend to keep the number of steps as small as possible.
To execute the command, we use a docker image called "codesys-ide:local". This image contains a full CODESYS installation, as well as some scripts to automate the most common CI/CD tasks. To execute those scripts, just run the wrapper "codesys" and pass the script name. In our case this was;
This command searches for all files ending with ".library" and build a file called ".compiled-library". Those compiled libraries don't contain source code anymore, have no connection to SVN and are packed into project archives w/o warnings. So they are easier to handle for the users for everyday tasks.
Build Packages
- codesys build-package
This command searches for files called "package.manifest". The folder, containing this file is packed into a CODESYS package. Those packages can be easily installed by your users, and they can contain libraries, projects, device descriptions and also third party files.
Naturally this is a final step, and you should have done all your build actions before.
For example:
Instead of:
Generate Package Manifest
- codesys gen-package-manifest
If you don't have a package manifest, yet, you can let this script generate one for you. It will search for folders containing device descriptions, libraries or projects and create a package manifest, which installs those files.
If the repository is an SVN repository with the folders trunk, branches and tags, the scanning starts for all these folders separately.
Obviously it makes sense to call this action prior to "build-package".
For example:
Build Bootapplications
- codesys build-bootapp
This command searches for files ending with ".project" and tries to build a bootapplication out of them. The bootapplication contains of mainly two files, ending of ".app" and ".crc". The name of the files is equal to the name of the project file. This differs a bit from the default in CODESYS, as the bootapplications there are named after the application in the project.
Another deviation is, that we are limited to one application per project. We only build the active one if there are multiple applications in the project.
The reason is simply, that this behavior is much better for a generic build system, that knows nothing about the interna of the projects.
