#15 CfUnit will undergo a name change
None
2021-04-24
2021-04-11
h-hermsen
No
Starting from version 1.2.0.0, CfUnit will undergo a name change to;
"co♻e: A unittesting framework for CODESYS".
Rest assured that the renaming will have no impact on the code or the licensing itself
The name change will steadily replace the old "CfUnit" name. As the entire repo will be subjected to be renamed, such things take time.
Answers
  • h-hermsen
    h-hermsen - 2021-04-11
    • Description has changed:
    Diff:
    --- old
    +++ new
    @@ -1,7 +1,5 @@
     Starting from version 1.2.0.0, CfUnit will undergo a name change;
    -"co♻e: A unittesting framework for CODESYS",
    +"co♻e: A unittesting framework for CODESYS", this renaming will have no impact on the code itself.
    -This renaming will have no impact on the code itself.
    -"co♻e"is pronounced as "co-unit".
    +co♻e is pronounced as co-unit.
    • status: --> open
  • h-hermsen
    Diff:
    --- old
    +++ new
    @@ -1,5 +1,6 @@
    -"co♻e: A unittesting framework for CODESYS", this renaming will have no impact on the code itself.
    +"co♻e: A unittesting framework for CODESYS".
    -co♻e is pronounced as co-unit.
    +Rest assured that the renaming will have **no** impact on the ccode or the licensing itself!
  • h-hermsen
    Diff:
    --- old
    +++ new
    @@ -2,5 +2,5 @@
    -Rest assured that the renaming will have **no** impact on the ccode or the licensing itself!
    +Rest assured that the renaming will have **no** impact on the code or the licensing itself!
  • h-hermsen
    h-hermsen - 2021-04-24
    Diff:
    --- old
    +++ new
    @@ -2,5 +2,6 @@
    -Rest assured that the renaming will have **no** impact on the code or the licensing itself!
    +The name change will steadily replace the old "CfUnit" name. As the entire repo will be subjected to be renamed, such things take time.
  • h-hermsen
    Diff:
    --- old
    +++ new
    @@ -1,4 +1,4 @@
    -Starting from version 1.2.0.0, CfUnit will undergo a name change;
    +Starting from version 1.2.0.0, CfUnit will undergo a name change to;
