Server IIS et Controller Wago 750-841
franck3751
2010-08-03
2010-08-16
  • franck3751 - 2010-08-03
    Hello
    is it possible to create a website locally on an IIS server using the build files of the Comptroller wago 750-841 so that the site points to the address of the controller.
    For now, I do happen to see the page in my web browser (IE, Mozilla) with the address http://localhost:8080/webvisu.htm because the IIS server points to 8080, the animation does not work in the status of the browser there is "Bad request".
    Poiuvez you help me a bit more .. ?
    Best regard
  • Avgur - 2010-08-16
    Try to check the file webserver_conf.xml in <codesys folder="" installation="">\CoDeSys V2.3\Visu. There is the option <webserver-port-nr> 8080 </webserver-port-nr>. Try to change it and maybe it helps...
    I don't quite sure, because Wago 750-841 has it's own webserver in linux and maybe you should tune up some linux system files.
    Good luck!</codesys>
