we ported your RTS to another Operating system.
My part was/is about the IO modules.
With Profibus, everything went fine, as the GSD files were available from the manufacturers (HMS, Siemens).
Afterwards, i wrote a module for GPIO (General Purpose IO), whose job it is to show an output-value (binary) using some LEDs.
The module is loaded fine by the RTS and even the Start-/DoneWriteOutputs functions are called.
However, i think i must write a cfg file, which describes the device, and load it into the configurator, to use the module in my PLC program.
Am I right ?
The problem is that i have no idea, how these cfg files look alike.
The available documents do not contain this information and i am in lack of an example.
So here comes the question :
What does an CFG file looks like, which defines a device, which provides 1 Byte of Output Size ?
Thanks,
Granus
Hi all,
i got it know (the Trial-and-Error-way).
Here is the CFG File i wrote :
; ----- Module -----
[Module.Card]
Id=1234
Class=CARD
Name=MPC5200
AdrEditable=Yes
SymbolicNames=unlocked
Icon=Plcconf.ico
DiagnosisSize=0
Channel1=Section=BYTE_Output,Name=OutCh_0,Adr=%QB3,AdrEditable=Yes,NodeIdEditable=Yes,Comment='Output
Channel 0'
; ----- Channels -----
[Channel.BYTE_Output]
Id=8033
Type=BYTE
AdrType=B
Class=Q
CreateBitChannels=true
; ----- end of file -----
Another thing that made problems was the IO module not returning DR_CAP_FLAG_WANTS_CONFIG on IODrvFctGetDeviceFlags.
That resulted in the fact that output-mappings werent established and the WriteOutputs function wasnt called.
However, its working now
Any suggestions ?
Regards,
Am I right ?
Thanks,
Granus
Hi all,
[Module.Card]
Id=1234
Class=CARD
Name=MPC5200
AdrEditable=Yes
Icon=Plcconf.ico
DiagnosisSize=0
Channel 0'
Id=8033
Type=BYTE
AdrType=B
Class=Q
Any suggestions ?
Regards,
Granus
