Call a Function Block
Romuald
2010-04-08
2010-04-09
  • Romuald - 2010-04-08
    I call a Program (PRG1) from System Events (event start for example).
    PRG1 have to send a email. But the function to do this is a function block and need multiple cycles.
    How to do this when PRG1 is called once and have only one cycle.
    I also notes that I can't put parmeters to call a program from System Events.
    It is possible from a Tasks Config but not from System Events.
    Thanks,
    Romuald.
  • Nitrozin - 2010-04-09
    • call a FB from your event wich sets a global bit
    • call PRG1 in main cycle as long as bit is true.
    • reset the bit in PRG1 when all stuff is send.
    Nitro
  • Romuald - 2010-04-09
    Thanks for you reply.
    Nitrozin hat geschrieben:
    - call a FB from your event wich sets a global bit
    Nitro
    So we can call a FB from an event ? When I press the F2 key, only PRGs are proposed.
    I don't understand how we can call a FB. We do not need to create an instance ? It does not seem to be possible in System Events.
    And as I said, apparently we can not use parameters for POU in System Events.
    I should mention that I use the version 2.3.9.13
    What I did that seems to work:
    System Event 'start' --> START_PRG
    PROGRAM START_PRG
    Β  Inst: FB;
    Β  error: INT;
    go := TRUE;
    WHILE go DO
    Β  Inst(var1 := '', .., send := go, error => error);
    END_WHILE
    In fact I simulates cycles with a WHILE boucle. Is the good way to do in CoDeSys development ?
    I don't think so. My WAGO stops responding
    - call PRG1 in main cycle as long as bit is true.
    - reset the bit in PRG1 when all stuff is send.
    Nitro
    Perhaps you want to say this:
    VAR_GLOBAL
    Β  Gstart: BOOL;
    Cyclic Tasks which calls --> PRG_WITH_FB
    PROGRAM START_PRG
    Gstart := TRUE;
    PROGRAM PRG_WITH_FB
    Β  Inst: FB;
    Β  error: INT;
    IF Gstart THEN
    Β  (* send = IN_OUT variable. Set to FALSE when finished *)
    Β  Inst(var1 := '', .., send := Gstart, error => error);
    Β  IF NOT send THEN
    Β  Β  Gstart := FALSE;
    Β  END_IF
