Dear all! I have an encoder Hengstler in CanOpen, but this does not have dip switches to set the address and network baundrate. The manual states that these settings should be modified by the Layer-Setting-Service (LSS) is defined in CiA DSP-305. I read the post l viewtopic.php?t=1224 l , but I donβt have best results.. Links for download: Manual: http://www.hengstler.de/gfx/file/shop/e ... pen_en.pdf Manual Tec.: http://www.hengstler.de/gfx/file/shop/e ... URO_en.pdf Manual Inst.: http://www.hengstler.de/gfx/file/shop/e ... ANopen.pdf EDS: http://www.hengstler.de/gfx/file/shop/e ... ANopen.zip
I need to modify this parameter. Can anyone help me?
Regards, Eduardo
I'm still working on that problem. Someone must help me?
Hello
Look here:
http://www.canopensolutions.com/english ... /lss.shtml m
Hello, I had the solution to the LSS. It was necessary to send a command first. Canid: 0000d byte 0: 0x80 byte1: device address
See: http://www.microcontrol.net/download/ap ... an1204.pdf
I used the functions and CanUser_Write CanUser_ReadImage for configuration and an oscilloscope to check the pulses in the network .
Thank's
Eduardo Schedler Estrela - Rio Grande do Sul - Brazil
Dear all!
Links for download:
Regards,
Eduardo
Hello
Look here:
Canid: 0000d
byte 0: 0x80
See:
Thank's
Eduardo Schedler
