Alarm handling in FB's
CodeEager
2011-09-08
2011-09-09
  • CodeEager - 2011-09-08
    I am new to CoDeSys, mainly I am quite impressed with what I have seen this far, however I wonder if alarm configuration may only be done in the application by using Alarm Configuration/Class/group and storage objects.
    I find it much more "natural" to define alarms as parts of the function blocks (e.g. a function block for a valve should issue/manage tha alarms related to the actual instance of this valve FB).
    This way it would automatically be added if you add the FB.
    Is this really not possible ?
  • shooter - 2011-09-09
    you can do it anywhere you like.
    im do not use the alarmhandler (only to test if plc is running)
    the rest is in function blocks
    look for a better software at w www.oscat.de w
    download the version for your codesys and the txt version you can read it, the docs are in english too.
  • CodeEager - 2011-09-09
    Thanks for info and link.
    Unfortunately my Deutsch is weak, do you know english language url ?
    Any hint of how to define alarm handling ?
    I want to define e.g. a FB called from within an outer FB, the inner one must be a kind of finite state machine which serves opc server acc0ording to opcfoundation AE 1.10 spec.
