I have several identical subsystems that can have many different fault conditions. It would be extremely time-consuming and error-prone if I put separate alarm conditions for each subsystem in the alarm configuration:
Expression              Type   Class   MessagePLC_PRG.systems[0].material.consumed DIG=1  WARNING  Materialdepletedonsystem0PLC_PRG.systems[0].material.jammed  DIG=1  INTERLOCK Materialjammedonsystem0PLC_PRG.systems[0].sensor.blocked   DIG=1  INTERLOCK Sensorblockedonsystem0...PLC_PRG.systems[1].material.consumed DIG=1  WARNING  Materialdepletedonsystem1PLC_PRG.systems[1].material.jammed  DIG=1  INTERLOCK Materialjammedonsystem1PLC_PRG.systems[1].sensor.blocked   DIG=1  INTERLOCK Sensorblockedonsystem1...PLC_PRG.systems[2].......PLC_PRG.systems[3].......
Is there a way that I could use placeholders like this?
Wherei:=0TO5Expression               Type   Class   MessagePLC_PRG.systems[$i$].material.consumed DIG=1  WARNING  Materialdepletedonsystem$i$PLC_PRG.systems[$i$].material.jammed  DIG=1  INTERLOCK Materialjammedonsystem$i$PLC_PRG.systems[$i$].sensor.blocked   DIG=1  INTERLOCK Sensorblockedonsystem$i$...
I would be okay with using some function to manually add the alarm to the alarm table, too. Something like:
FORi :=0TO5DO
 IFsystems[i].material.consumedTHEN
  message :=CONCAT('Material depleted on system ', SINT_TO_STRING(i));
  NewAlarm(
   expr :='PLC_PRG.systems[i].material.consumed',
   type :=ALARMTYPE_DIG1,
   class :='WARNING',
   priority :=0,
   msg :=message
END_FOR
As long as I don't have to change six pieces of code to fix one bug!
apart from the expr where you use [i] (which will not work) it is good.
you will have to keep in your own array the status as this is lost due to the loop.
shooter hat geschrieben:
The NewAlarm function doesn't really exist. I just put it there to show what kind of function I'm looking for. (In the real thing, I'm going to CONCAT the value of i into expr -- provided that something like NewAlarm really exists.) I am already storing the status in my own array; I am trying to cause an alarm whenever any subsystem faults. The difficult thing is, I want to:
1) Have the message show which of the many subsystems faulted, and
2) Not have to maintain six different copies of the alarm, the only difference being the i variable.
My question again: Is there a way to do this?
Related
Talk.ru: 1
Talk.ru: 2
Talk.ru: 3
