MONITOUCH - 2019-10-28
I would like to communication CoDeSys on PC with a device supporting Modbus TCP/IP directly.
<configuration>
CoDeSys on PC as Modbus TCP/IP Master 192.168.0.20
The device as Modbus TCP/IP Slave 192.168.0.10</configuration>
<question>
How can I set in the communication setting?
Now, the gateway shows that IP-Address is "localhost" and Port is "1217".
Next one shows my PC name.</question>
<communication and="" pc="" between="" device="" the="" check="">
The PC and the device is communicating by ping on the command prompt.</communication>
<setting control="" on="" win="" device(codesys="" codesys="" under="" v3)="">
Ethernet(Ethernet)=>ModbusTCP_Slave_Device(ModbusTCP Slave Device)</setting>
