yes there is, but not as a part of CoDeSys.
Make export files of both of entire projects (Project ==> export). This will create plain text files, which can be compared by several tools (e.g. Total Commander, WinMerge ...).
is there a way to compare 2 .pro files (Codesys v2.3) and find all the differences between them ?
Hi pnn,
Go to project menu and you can find compare in that.You can compare two .pro projects with that.
Have a good day
Hi pnn!
You can also make a 'Merge' between two projects. It's in the same menu.
/TorbjΓΆrn
