you cannot, because the variables stay in memory and the value is going to be what it was the last time.
i was looking for something like this and my solution was the following:
a default value outside the range of a normal value would show that the variable had not been set. this input value could then be overwritten anytime the function is called and you would know if the input was assigned or not.
for example: and input in1 with the range of 0..100 as value range
the function block itself has to make sure the input is always at a value outside the defined input range then it can decide if the input valkue has been set or not
var_input
in1 : real;
end_var
in in1 <= 100 then
input := in1
end_if;
in1 := 99999;
Hi, everyone,
I have a function block with 3 inputs (IN1,IN2,IN3), but sometimes I call the function just with input of IN1, or IN2?
For example: FB(IN1:=XX) or FB(IN2:=XX) or FB(IN1:=XX,IN2:=XX) etc.
How can I know which input is assigned when the function block is called?
Many thanks,
var_input
in1 : real;
end_var
in in1 <= 100 then
input := in1
end_if;
in1 := 99999;
