I am a newbie at Codesys and trying to concatenate some time variables into text, so that I can pass this information to a server via an Ethernet socket.
I am trying to convert this vairable "CurDate" which is an LWORD to a STRING (variable named "Text"). I am then trying to decode each digit into it's ASCII character into an array;
  CurDate: LWORD;
  Text : STRING;
  Index : INT;
  Var1AT%MB100 : STRING;
  Var2AT%MB100 : BYTE;
  ascii : ARRAY[0..64] OFBYTE;END_VARCurDate:=(DTNow.Year*10000000000)+(DT_Month)+(DT_Day)+(DT_Hour)+(DT_Minute)+(DT_Second); (* this value equals 20130103185505, at the moment *)Text :=STRING(CurDate);FORIndex :=1TOLEN(Text)BY1DO
  Var1 :=MID(Text ,1,Index);
  ascii[Index-1] :=Var2;END_FOR;
I get an Error 4268: Expression expected on the line "Text := STRING(CurDate);", I can't seem to find an "LWORD_TO_STRING()" function??
Any assistance would be greatly appreciated.
2013-01-04
Originally created by: 99bobster99
After digging through some manuals, I came up with this solution. It is not pretty but it works (please let me know if there is a more elegant way of doing this);
CurDate:=DT_Year+DT_Month+DT_Day;Â Â Â Â Â Â Â (* CurDate := 20130104 *)CurTime:=DT_Hour+DT_Minute+DT_Second;Â Â Â Â (* CurTime := 92530 *)(*ConverttheLWORDinto2STRINGvariables*)Text1 :=LREAL_TO_STRING(CurDate);Â Â Â Â Â Â Â Â Â Â (* Text1 := "20130104" *)Text2 :=LREAL_TO_STRING(CurTime);Â Â Â Â Â Â Â Â Â Â (* Text2 := "92540" *)IFLEN(Text2)=5THENText2 :=INSERT(Text2,'0',0);Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â (* Text2 := "092540" *)END_IF(*FillDataArraywithASCIIcharactersrepresentingtheSTRINGcharacters*)Text3 :=CONCAT(Text1,Text2);Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â (* Text3 := "20130104092540" *)FORIndex :=1TOLEN(Text3)BY1DO
  Var1 :=MID(Text3,1,Index);
  Array_DT[Index-1] :=Var2;END_FOR;
Everything works perfectly, I get the ASCII equivalent data in my "Array_DT" array, for each character in "Text3". Any ideas on how to make this code more compact?
you can have a look at http://www.oscat.de nice lib
