Does anyone know how to assign components of a structured data type to a definite address using CoDeSys? For example, I would like to have a Data type as follows:
TYPETestData:STRUCTÂ Â Data1:WORD;Â Â Data2:WORD;Â Â Data3:WORD;END_STRUCTEND_TYPE
And in the Global variable table, I would like to have something like this:
VAR_GLOBALÂ Â TestData1:TestData;Â Â TestData1.Data1AT%QW1500;Â Â TestData1.Data2AT%QW1501;Â Â TestData1.Data3AT%QW1502;END_VAR
I know it does not work with the above syntax. But does anybody know the right syntax? This would save me a lot of effort.
in a Multiprog wt (CoDeSys competitor) written application I used the following syntax:
VAR_GLOBALÂ Â TestData1AT%QW1500:TestData;END_VAR
This will allocate 3 WORDs QW1500 and up, in the same order as the TestData structure is declared.
It looks a bit strange, since the structure is bigger than 3 WORDs, however, it worked fine.
I guess, CoDeSys will do it in the same manner. Both of the systems are IEC1131 compliant ...
Rolf, Thanks a Ton. I tested this. It works with CoDeSys too.
I should have guessed. In the same project, I had assigned a DWORD to a %QW address and realized I made a mistake because the DWORD took values from the adjacent address too. So obviously the address is only a starting address that fills up the variable to its entire width.
I really think the CoDeSys guys should mention this possiblity in the help file under the "Variables declaration" topic.
As a side note I have used addressed memory to pull bytes out of words and put them back in a different order. You can define an array of words at a marker address and then define an array of bytes at the same address. This effectively overlaps the memory like a union in C.
