s45er - 2021-11-30
Hello, trying to integrate the C code in Automation Builder. The purpose of this code is to convert base64 encoded message. The C function will be called in CoDeSyS.
The base64 converter code works successfully in MPLAB (running on PIC32)
However when I try to integrate it, I cant do it, since in available data types I cant choose array of uint, only data types without array. The picture shows the dialogue of C code app in Automation Builder (CoDeSys data types).
I had a thought maybe I can use a STRING, as array of UINT, in CoDeSys by applying pointers, but not sure.
May be some has encountered the same problem ? Or knows possible solution ?
I apologize for offtopic, but dont know where to ask, thought CoDeSys forum best place, since Automation Builder refers to CoDeSys data types.
Last edit: s45er 2021-11-30
