Reset an Array[] in one line, possible?
2013-03-22
2025-04-03
  • fredleemans - 2013-03-22
    I would like to know if it's possible to "Reset" all the index of an array to a value, with one line?
    For example:
    I have a array of 5 real. array[1]= 1.12, array[2]= 2.23, array[3]= 3.45, array[4]= 4.56, etc...
    In a phase of my sequence, I need to "Reset" completely my array[] to a specific value, for example 0.
    Is there any commands that allow that or should I use a Loop to "Reset" each index one by one...?
    eg: array[1..5] := 0; or something like that?
    Thank you for your help,
    Regards,
    Fred
    Related
    Talk.ru: 1
    Talk.ru: 2
    Talk.ru: 3
  • Strucc - 2013-03-22
    There is no standard way to do this.
    However, if you don't aim platform independence, and your target platform support SysLibMem library, you might want to try:
    SysMemSet(ADR(MyArray),0,SIZEOF(MyArray));
    However, this only works, if you'd like to reset everything to 0, or it's an array of bytes.
    I'm not sure about the performance difference between this solution and a standard ST for loop...
    Ok, I'm gonna to see if I have SysLibMem library.
    I want reset all to '0', so it would be perfect.
    Anyway, I can measure the time for performing the 2 methods and compare it... Finally a "For" Loop is not so big to write.
    Thank you for your idea,
    Regards,
    Fred
  • jampid
    jampid - 2025-04-03
    Bonjour,
    La librairy est SYSMEM en Codesys v3.5.
    Pour accéder à la fonction : SysMem.SysMemSet.
    Il y a plein d'autres fonctions intéressantes : SysMemSwap, SysMemMove, SysmemCpy, ...
    Cela évite de créer des Boucles et permet de bien utiliser ADR() et SIZEOF()
    Il existe aussi une librairie CAA Memory qui mérite intérêt;
    Par exemple MEM.MemFill pour remplir un tableau d'octets.
    Bons développments!
    Il suffit d'ajouter ces bibliothèques dans le gestionnaire de bibliothèque pour les utiliser.
    JM
