Web-Serverstartedon:  Hostname:localhost  IP-Address:127.0.0.1  Port:8080  Rootdirectory:D:\ProgramFiles\WAGOSoftware\CoDeSysV2.3\ConnectedtoPLC:  IP-Address:192.168.1.23  Port:2455  Byteorder:intel************************************************SysSockConnectetoPLC.
But I can't see the Wago visualization that was downloaded to the PLC.
Further information
Detailed Information about the programming and visualization, especial the
Web Visualization, please refer to the manuals „WAGO-I/O-PRO CAA
(CoDeSys)“.
You can find these manuals on the CD-ROM „WAGO-I/O-PRO CAA“
Hi there,
I have a problem with Wago 750-841 and CoDeSys V2.3.
When I try to run WebServer and then visit localhost (127.0.0.1:8080) shows:
(under Opera) Access Error: Page not found
(under IE) same just other error message
Well, its HTTP error 400.
The CoDeSys is installed under directory:
Webserver:
The PLC is configured with such parameters:
I'm running WebServer (demo mode) under cmd.exe,
file webserver_conf.xml is renamed to _webserver_conft.xml
The message from CoDeSys is:
I also tried ```
http://127.0.0.1:8080/webvisu.htm
Changing WebServers port doesn't help.
Can you help me? What I'm doing wrong.
Thanks.
J posted the same problem, in the topic "Visualisation".
My version of CoDeSys is installed on the C disk
There is something wrong in the C:\Program Files\3S Software\CoDeSys V2.3\Visu\ webserver_conf.xml file
<webserver-configuration></webserver-configuration>
<webserver-port-nr> 8080 </webserver-port-nr>
<target-port-nr> 1200 </target-port-nr>
<target-ip-address> localhost </target-ip-address>
<use-file-upload-dir> true </use-file-upload-dir>
<file-upload-dir> C:**Programme\CoDeSysV23\ </file-upload-dir> <file-upload-dir> C:**Program files</file-upload-dir>\CoDeSysV23\
And its works perfectly !!
I hope this can help you
Thank you for reply.
I read that topic, but I thought, I just need to change the path for the right one, not for some fictional.
I'll check this solution, next week.
I'll write you back if it worked.
It didn't work in my case.
But I found another solution in some cases.
The PLC has it own IP address so i forwarded ports to it. Unfortunately I haven't find how to do this under Windows XP using only cmd.exe
The program i used was AnalogX PortMapper.
If we have a router, it's even easier.
If any one know how to do it under windows console, please PM me.
Thanks for help.
You shoudn't run webserver on your PC. WAGO 750-841 has own webserver. It's installed and runned in PLC OS context.
1) Connect to your PLC from Web-configuration page. In your case:
2) Create webvisu and activate webvisu in target options.
3) Install java-machine
4) Type
http://192.168.1.23:8080/webvisu.htm
``` in browser. Enjoy!
As well, quote from WAGO manual
Further information
(CoDeSys)“.
