Setting Steps in SFC
Sgsims
2011-09-14
2011-09-16
  • Sgsims - 2011-09-14
    Is there anyway to Set / Reset a step in a SFC? Looking for a way to make a step active other than using the transition.
  • shooter - 2011-09-16
    yes it is possible but why should you do this.
    look at <stepname>.x this is a boolean and shows if the step is active.
    if you use <stepname>._x := true and the step is not active yet ( .x) then the step will be executed the next cycle it is called.</stepname></stepname>
    however you must watch as this could mean several steps are active in one SFC.
    look for step2.sfccurrentstep etc.
    search in help for sfc status scan
