Real to word conversion for analog outputs
CME
2013-06-12
2013-06-14
  • CME - 2013-06-12
    Most of the libraries for analog processing ( 0-10V, 4-20mA…) are using β€œreal” as output. For an analog output module you need a datatype β€œword”. How can I easily convert real to word?
    Does a library exist with a function REAL_TO_WORD function?
    I think it must be also possible with pointers but have anyone experience with it and/or having a example program?
  • ndzied1 - 2013-06-12
    The standard includes a REAL_TO_WORD() function. You only need to check with your hardware documentation to see what numerical value corresponds to the real world voltage or current signals.
    Usually you perform a scaling function first to create the number you need to send to the analog output, for instance, a 12 bit analog output would likely take numbers from 0 to 4095.
  • shooter - 2013-06-14
    The word output is sometimes strangely formatted.
    but in general the conversion like ndzied tells is working,
    Inputs are sometimes shifted so will need special attention before scaling.
    Have a look at the oscat library with many functions for this.
