I need to get my floats into strings in the format I want. I want to specify # of decimals. This data is being logged to a .csv file. The only option I appear to have is REAL_TO_STRING, then screw around with the resulting string. The biggest problem I have now is that values < 1.0 are coming in as engineering format... so I get -9.733445E-1 for example.
What is the correct solution to this situation? Everything in Codesys seems to be built on C building blocks so why can't I just do a sprintf type of funciton and specify %.2f or something like that?
Any help is appreciated. I really don't feel like parsing out E values in my string to try to figure out where to move decimals around. It's really getting excessive for something so simple. I already have a ton of code to get the # of decimals I want with values that don't have E in them.
multiply your number by 100 to get two decimals
make a real_to_int conversion
this you can write direct to your CSV (as this will only take little memory
or divide it by 100 and make it a real again.
I do leave it in INT as my calc (openoffice) will calculate it back in correct numbers.
