RS232
Dokee
2008-07-24
2016-09-30
  • Dokee - 2008-07-24
    How to use a RS232 modul with codesys? I found a FB about this module, but the help doesn't allusion the use.
    May I get some example about RS232?
    Thanks,
    Dokee
  • TimvH
    TimvH - 2008-08-12
    It fully depends on which device you have, but in general attached code should give you an idea on how to use the standard serial communication library. Import it in a new project and add the syslibcom library to this project.
    You manually have to set the bits to execute the FB's.
    PLC_PRG.zip [1.45 KiB]
  • mravlincek - 2016-09-26
    Why can't I open this file? I have the same problem, I am trying to do a simple program where the device would open the RS232 port and read it. Of course also displaying somehow what it was read. I am working with Eatons XVS440 panel and trying to use the RS232 port.
  • shooter - 2016-09-30
    this post is 8 years old so check codesys site direct.
