Result of multiplication always 16 bits?
astrand
2012-08-04
2012-08-05
  • astrand - 2012-08-04
    This code causes my PLC to crash:
    dp: POINTER TO ARRAY[0..7] OF BYTE;
    soc: BYTE;
    soc := 60;
    dp^[3] := soc * 2;
    If I add UINT_TO_BYTE() around the multiplication, it works. It seems like the result of a multiplication - even with small numbers - is an integer, ie with 16 bits or more. Can someone confirm this; is this specified somewhere?
    Related
    Talk.ru: 3
  • shooter - 2012-08-05
    not reaaly but you did not define the multiplication factor (2) as a byte thus this is automatic an integer thus the result is an integer.
    define the 2 as a constant byte and you will see it works.
