Simple PWM simulator
csparks
2011-03-22
2011-03-22
  • csparks - 2011-03-22
    I'm new to CoDeSys and I was wondering if there was a base PWM simulator program floating around anywhere. Ideally, I need an 80 Hz signal and need to be able to adjust the voltage (24VDC max) to control a fan. I wanted to get my hands on a base program and just teach myself how to tweak it to get it to work properly. I will also be using an EPEC 2038 module for this if that is any help.
    Thanks.
  • shooter - 2011-03-22
    just because you are a beginner
    look at w www.oscat.de w lots of pieces of program to work with.
    pwm is a counter to a full byte for example and each time you are passing add one and check if you are above zero and below setting. then output is on else output is off.
