Now a few things: You don't need to add them to anther variable you already have them in the array but from my experience you will want to know how to read a 16 bit variable and 32 bit variable from your data array:
FUNCTIONIO_BYTES_To_WORD:WORD(*  IN0 = LSB  IN1 = MSB*)VAR_INPUT  In0    :BYTE;  In1    :BYTE;END_VARVAR  wTemp  :WORD;END_VARwTemp  :=In1;wTemp  :=SHL(wTemp,8)ORIn0;IO_BYTES_To_WORD  :=wTemp;
So if you did the following:
word1 := IO_BYTES_TO_WORD(IN0:= Byte0, IN1:= Byte1); (* this will give you a word / int 16 bit from your two data bytes *)
Follow the same logic for getting a DWORD 32bit from 4 bytes.
Hi, all, i am starter for codesys system.
Now i have read the 8 bytes array from canbus.
but i need the data byte1 and 2,
i have no idea how to get these data. please help.
Hi!
Is it this you need?
Your arrCAN probably have from [0]-[7]
arrCANbus[0] = byte 1
arrCANbus[1] = byte 2
arrCANbus[x] = anybyte in the range see above.
/Torbjörn
thank you very much!
Since you are that new I would like to be clear. It appears that you said you want to read the data then you would do the following:
Byte0 := CanDataRec[0];
Byte1 := CanDataRec[1];
Byte2 := CanDataRec[2];
Byte3 := CanDataRec[3];
Byte4 := CanDataRec[4];
Byte5 := CanDataRec[5];
Byte6 := CanDataRec[6];
Byte7 := CanDataRec[7];
Is that any option to Insert / delete the element from Array?
I don't think so. Usually your are dealying with non dynamic variables in PLC's.
I don't know how it is the Codesys 3 with C/C++ code.
/Torbjörn
