Batch installer / program download
starkgray
2010-10-18
2010-10-18
  • starkgray - 2010-10-18
    Does anyone know if there is an application or library included with CoDeSys that allows for a scripted download of a PLC program? I'd like to make a batch installer for multiple PLC images. The images would have been built in CoDeSys and tested before the batch update. The CoDeSys webpage has a library that looks promising:
    http://www.3s-software.com/index.shtml?en_PLCHandler_V3
    Thanks,
    Doug
  • Ralph Holz - 2010-10-18
    You can use a Command File --> refer help by keyword Command File or the CoDeSys Service-Tool --> contact e sales@3s-software.com e
    br.
    Ralph
    Thanks for the info, I'm looking into the CST add-on now.
    Any idea if it's possible to just ftp the image of the PLC (the .PRG and .CHK files) to the controller? I logged into the PLC after a download and found a DEFAULT.PRG and DEFAULT.CHK in the /data directory. These files are the same as the PRG and CHK files in the codesys directory after creating a "boot project". I tried to replace them on the PLC: set the perms, user and group the same as the original files; then issued a restart, but I could no longer connect with CoDeSys. Do you know if there are some other files that need to be updated?
