yes that is possible, however it means a lot of memory has to be used for array, if possible use vectorpoints, it saves on memory, and it is faster.
It is depending of the precision needed.
i used a vector array, and the points were connected with a polygonline.
on the graph i had put 100 points all on same place (with a texteditor, and i can change the relative points with the software.
Is it possibile to plot X-Y trend in CODESYS?
X is position of axis 1 and Y is position of axis 2.
Hi Paul,
Thanks a lot for your response.
if needed more info, please give more info.
