Using Ethernet.lib
raoul
2006-07-21
2006-07-24
  • raoul - 2006-07-21
    Hello all.
    I'm trying to use the Ethernet.lib library with a 750-842 controller. I want to make an UDP server listenning to UDP packet wich are broadcasted on the network.
    I'm doing this:
    socket: ETHERNET_SERVER_OPEN;
    Read: ETHERNET_READ;
    IF (socket.SOCKET = 0) THEN
    Β  Β  socket(EN:=1, TYP:=SOCK_DGRAM, PROTO:=IPPROTO_UDP, PORT:=4545);
    Read(EN:=1, SOCKET:=socket.SOCKET, DATA:=buffer);
    Read(EN:=0, DATA:=buffer);
    IF (Read.LEN_OUT > 0) THEN
    Β  Β  (* Do somthing *)
    The socket is successfully created with no error, but when a packet comes nothing is read from the ETHERNET_READ function block...
    Why? Does anybody know if I've done something wrong?
    Thank
    Raoul
  • Erik BΓΆhm - 2006-07-24
    Did you try it like this:
    (* Do somthing *)
  • raoul - 2006-07-24
    Yes I tried that, but It's exactly the same...
    Raoul
    I have a (fully working and tested) Sample for you.
    Maybe it helps you to understand the mechanism.
    Greets
    Erik
    WagoEthernetServer.zip [12.42 KiB]
    Thank you, I'll try this example...
    Raoul
