User-Defined Data Types
martino
2012-10-15
2012-10-16
  • martino - 2012-10-15
    I'm very new to Structured Text and dealing with user-defined data types. I've looked online and on the codesys manual, and from what i've read, it seems like this should work:
    TYPE HistoryArr :
    STRUCT
    BaseRequested:REAL;
    BaseActual:REAL;
    AngleRequested:REAL;
    AngleActual:REAL;
    DateAndTime:DT;
    END_STRUCT
    END_TYPE
    Codesys wants me to declare HistoryArr.. What type would I declare this as? eg. WORD, INT, etc
  • shooter - 2012-10-16
    in your POU you say :
    history array[1..10] of Historyarr;
    in the ST you write for example
    history[1].anglerequested :=setangle;
    it works the same as when you say array of INT but now the whole structure can be used.
    Related
    Talk.ru: 1
  • martino - 2012-10-16
    Thanks, This helps a lot
    Also I should note that I was declaring the TYPE and STRUCT in the ST code, but realized I was supposed to add it in the Data Types Tab
