TCP Socket example?
Antti
2006-05-04
2018-01-29
  • Antti - 2006-05-04
    Could someone nice post SysLibSockets library(SysLibSockets.lib) example?
    Maybe TCP-server and TCP-client..
  • B.Roth - 2006-05-04
    Ask at the 3S-support for the TcpUdplib.lib and for an example.
  • Anonymous - 2006-05-04
    Originally created by: Frank Hailer
    Hello
    There's a very useful example project, TcpUdp.pro (enclosed). It includes a TCP Server and Client as well as a UDP Producer and Consumer. The functions within come from the library TcpUdpLib.lib and are modified a little bit.
    Bye, Frank Hailer
    TcpUdp.zip [11.01 KiB]
  • Antti - 2006-05-08
    Hi!
    Thanks from example. I got my project working
  • Antti - 2006-06-12
    Actually I still have one problem. I can reveive messages from my client(LabView-prgoram) to my Codesys-server, but I can't send messages to Client. I get allways -1 value from Codesys SysSockSend-function. If I check last "TCP/IP API Error Code", I get error "235 Operation would block". Is there problem with socket options, or something else?
  • Anonymous - 2008-11-12
    Originally created by: Stefano.Casarini
    Thanks for the TCPUDP example
  • KiranK - 2012-03-14
    Antti hat geschrieben:
    Hi!
    can u give me the TcpUdpLib.lib fast i am in need
  • jlm60 - 2014-06-06
    Looking for a "exemple.pro" to create a tcp server nonblocking
    that proposed above is blocking "tcpudp.zip"
    Thank you in advance for your help,
    jlm
  • danyamian - 2018-01-29
    Frank Hailer hat geschrieben:
    Hello
    Bye, Frank Hailer
    Hi, How can I open the example project "TcpUdp.pro" in CoDeSys V3.5?
    Thank you very much.
    jlm60 hat geschrieben:
    jlm
    Hi, How can I open the example project "exemple.pro" in CoDeSys V3.5?
    Thanks you very much!
