Can anyone help me with CRC_CHECK and CRC_GEN libraries from oscat304.lib.
My project is using a Wago 750-650 RS232 card to communicate with a laptop. The customer has asked me to use crc and i found the oscat library after some seaching. My problem is, i don't know how to use them. All the information i can find is in German. Can anyone provide me with an example codesys project or provide a step by step guide to implement CRC.
Thank You
Dave
IF pReceiveStr = 0 THEN ( receive buffer with address of receivers initialize string )
pReceiveStr:=ADR(ReceiveString);
END_IF;
IF Receive_Buffer.Index>0 THEN ( new data is received )
FORi:=0TO255DOpReceiveStr^[i]:=16#00; (* receive buffer delete *)END_FOR;FORi:=0TOReceive_Buffer.Index-1DOpReceiveStr^[i] :=Receive_Buffer.Data[ i ]; (* ring buffer data in receive buffer to copy *)END_FOR;M_RECVSTR:=TRUE;
oscat304.lib all help about CRC functions in English
CRC_CHECK
FUNCTIONCRC_CHECK : BOOLVAR_INPUT
  pt : POINTERTOARRAY[0..32000] OFBYTE;
  Polynom_L : DWORD;
  Polynom_32 : BOOL;END_VARVAREND_VAR(*version1.1  16. mar. 2008programmer   hugotestedby    tobiasCRC_CHECKchecksablockofdataforacrcchecksumandreturnstrueisthechecksumis0andtherforeaerrorfreedatatransmission.
theCRCPolynomisspecifiedwiththeconfigvariablePolynom_Lwhichholdsthelowest32bitsofthepolynomandPolynom_33whichholdsbit33ofthePolynom.
APolynomx4+X+1isrepresentedby10011.
Theinputdataisanarrayofbyteofanysize, thefunctioniscalledbyCRC_CHECK(ADR(array),SIZEOF(array)).
CRC_GEN
FUNCTIONCRC_GEN : DWORDVAR_INPUT
  Polynom_L : DWORD;
  Polynom_32 : BOOL;
  init: DWORD;
  XOR_out : DWORD;
  rev_in : BOOL;
  rev_out : BOOL;END_VARVAR
  polynom : DWORD;
  p_length : INT;
  BS : BYTE;
  data : DWORD;
  count : BYTE;
  temp : BOOL;
  step: INT;
  s4: INT;END_VAR(*version1.4  16. mar. 2008programmer   hugotestedby    tobiasCRC_GENgeneratesaCRCchecksumfromablockofdataandreturns thechecksuminaDWORDtobeconnectedtothedatafortransmission.
Theinputdataisanarrayofbyteofanysize, thefunctioniscalledbyCRC_GEN(ADR(array),SIZEOF(array)).
Thank You
Dave
Try to google "A painless guide to CRC error detection algorithms"
Good luck!
Thanks for the reply Avgur.
But my problem is that i don't know how to use the CRC_CHECK and CRC_GEN functions from the oscat304.lib
What i need is a guide on how to use the two functions.
My code so far is below.
PROGRAM COMM2
COMM2( bCOM_PORT_NR := 2,
END_IF;
END_IF;
IF CLEAR_BUFFER THEN ( new request will be sent )
Receive_Buffer.Index := 0; ( receive buffer delete )
CRC:= CRC_CHECK(pRECEIVESTR, I, 469, Polynom_32);
Any help would be appreciated.
Dave
CRC_CHECK
CRC_GEN
