stop when you do an binary AND the result is still a word.
you must convert it by WORD_TO_BOOL to work correct, and yes the shortcuts will work, but are not easy to read, and are not in IEC
In other dialects I have done something like:-
bool_var := (int_var = 53);
ie the boolean is set TRUE if the int equals 53 otherwise it is FALSE.
can I do this here?
Yes you can
thanks for the reply. I got my example wrong - what I was actually trying to do was as below.
bool_var := (int_var AND 8);
This will not work. That is not a boolean expression. But the first example should work. Happy CoDeSysing!
Hi!
What I understand is that you can do a bit compare but only with WORD types.
BOOL := WORD AND 2#10010010
/T
