There is no variant types in codesys so creating a real printf with placeholders like %.3f and so will be tricky.
I have made this function though that takes a input string and replaces all # characters with a value.
Note that this is written for CodeSys 3 so uses // as comments.
FUNCTIONFormatString : STRINGVAR_INPUT
  Format: POINTERTOSTRING;
  Value : POINTERTOSTRING;END_VARVAR
  CurResult: POINTERTOBYTE;
  CurValue : POINTERTOBYTE;END_VAR//MakeacopyoftheinputstringFormatString:=Format^;CurValue :=Value;CurResult:=ADR(FormatString);WHILE(CurResult^<>0)AND(CurValue^<>0)DO
 Â
  //Foundaplaceholder(#)
  IFCurResult^=35THEN
    CurResult^:=CurValue^;
    CurValue:=CurValue+1;   Â
  END_IF; Â
 Â
  CurResult:=CurResult+1;END_WHILE
Note that if there are more # in the format string then the value it wont replace them with spaces. It would be an idea to add code for replacing the remaining, connected # with spaces.
Hi is there an equivalent to printf in Structured Text. I have to currently create strings by nested CONCAT statements.
Is there a better way?
Use a simple UDP protocol.
Alex
UDP - are you talking about User Datagram Protocol...can't quite see the relevance with writing several strings into a single string.
Could you elaborate???
Example:
String c will contain "Hello World" after this.
