wago 750 84.. <-> proface ST 403
2007-02-26
2007-02-28
  • Anonymous - 2007-02-26
    Originally created by: kees kraaijeveld
    I have a wago controller programmed with CodeSys and a Proface screen ST403 and I have communication with Ethernet between these components
    I have problems with the addresses
    Codesys uses for instance addres 256 two times, for sending (word out) and receiving ( word in ).
    The The sent information from Word out 256 returns to Word In 256
    Does anyone have same experience, or a solution?
  • Uwe - 2007-02-27
    Hello kees,
    at the follow link you can find a documentation about the plc-addresses
    and the modbusfunctions for WAGO contollers and couplers
    http://www.wago.com/wagoweb/documentati ... 00003e.pdf
    If you use a 750-841 or a 750-842 normaly it is a better way to use the FB
    "ETHERNET_TERMINAL_MODBUSSLAVE".
    Inside the wago-specific library "ModbusEthernet_04.lib" (provided by WAGO)
    you can find this FB.
    This FB is an modbus-server and this server maps the modbusaddresses to
    a wordarray inside the plc.
    You can run this server at a free port (like 2500) in the plc.
    At proface you have to adjust the communication to this port.
    For more information please contact the wago support.
    Note :
    This informations are wago specific. Systems of other manufacturers can work by an other way.
    Uwe
  • Oberchefe - 2007-02-27
    is for Modbus on serial Port.
    For Modbus Ethernet there's no library needed.
  • Uwe - 2007-02-28
    Hello Oberchefe,
    i am sure ETHERNET_TERMINAL_MODBUSSLAVE is a modbus-TCP-server
    for Ethernet not for serial ports.
    For modbus at serial port you can use the library "TerminalSlave_04.lib" .
    Both lib's have the same userinterface inside the plc so it is very easy
    to switch from Modbus-TCP to Modbus-Serial.
    Inside the firmware of the Wago-Controllers there is a Modbus-TCP-Server implemented on port 502.
    You are right, for use this server you don't need a library.
    But this server allows a direct access to the physical inputs / outputs and have an own
    userinterface.
    I think it's better to use ETHERNET_TERMINAL_MODBUSSLAVE as a second TCP-Server
    on an other port.
    So you can controll all outputs by the plc, you have a simple interface and it is easy
    to switch to a serial communication
    ( you have only to replace ETHERNET_TERMINAL_MODBUSSLAVE by TERMINAL_MODBUSSLAVE_RTU_EN ).
    This information is valid only for WAGO-Systems 841 / 842.
    Uwe
  • Oberchefe - 2007-02-28
    You're right, for sure. I didn't realize "ETHERNET" in the name.
