Advanced pointer to struct members
2018-12-06
2022-01-27
  • tjarcoboerkoel - 2018-12-06
    Hi readers,
    If I have a structure called sHisto:
    STRUCT
    History: ARRAY [1..64] OF REAL:
    MaxValue: REAL;
    MinValue: REAL;
    AvgValue: REAL;
    END_STRUCT
    And I pass it to a functionblock as a pointer:
    Measurement: POINTER TO sHisto;
    How do I reference the members inside a functionblock? Is the following right?
    Measurement.History[3] := 1.0; //set a single array value
    temp := Measurement.History[3]^ ; //get a single array value
    Measurement.MaxValue := 5.0; //set a member variable
    temp := Measurement.MaxValue^; //get a member variable
    SomePointerToReal := ADR(Measurement.MaxValue); //pass the addr of a value
    SomePointerToRealArr := ADR(Measurement.History); //pass the address of an array
    SomePointerTosHisto := (Measurement); //Pass the address of the structure
    Best regards,
  • Lo5tNet - 2018-12-06
    Someone will correct me if i'm wrong but when you use a pointer and want to access the values directly you need to de-reference it by using the ^. The de-reference comes after the variable pointer name and before the struct member.
    So to access a pointer inside the FB you would use:
    Measurement^.History[3] := 1.0; //set a single array value
    temp := Measurement^.History[3] ; //get a single array value
    Measurement^.MaxValue := 5.0; //set a member variable
    temp := Measurement^.MaxValue; //get a member variable
    If you are trying to pass the addr of a value while still in the FB you wouldn't need the ADR() since it is already referenced as a pointer. Otherwise you are passing an address of an address.
    SomePointerToReal := Measurement.MaxValue; //pass the addr of a value
    SomePointerToRealArr := Measurement.History; //pass the address of an array
    SomePointerTosHisto := Measurement; //Pass the address of the structure
    Related
    Talk.ru: 3
  • alebrije - 2022-01-27
    I would like to save some values in a structure named Test
    The structures is
    TYPE test :
    STRUCT
    generalinfo :general; // 2 variables as string
    testfreatures : freatures; // 2 variables as string
    END_STRUCT
    END_TYPE
    I'm using a pointer to the struct test
    INIValues1 : POINTER TO ARRAY [0..1000] OF STRING;
    INIValues1 := ADR(Test);
    // I want to write the values as follow
    INIvalues1^[0].^[0] := 'Test';
    How can I mange to do this... I would like later only to replace the struct so my function fits for many different structures
  • fajean - 2022-01-27
    To achieve what you want, you do not declare a "POINTER TO ARRAY[] OF STRING". You declare a "POINTER TO STRING". You can use the array subscript notation directly with this pointer. The array subscript notation performs dereferencing, just like using "^". In fact, ptr[0] and ptr^ are equivalent as far as I can tell.
    PROGRAM MAIN
      INIValues1 : ARRAY [0..1000] OF STRING;
      INIValues1_ptr : POINTER TO STRING;
    INIValues1_ptr := ADR(INIValues1);
    INIValues1_ptr[0] := 'Test';
