cant install runetime on 750-8202
naps
2024-09-29
2024-10-01
  • naps - 2024-09-29
    im trying to install the 3.5 Runtime on a a fresh image on my 750-8202.
    Product Description: WAGO 750-8202 PFC200 CS 2ETH RS
    Firmware Revision: 03.10.08(22)
    df -h
    Filesystem Size Used Available Use% Mounted on
    ubi0:rootfs.1 82.5M 66.5M 11.8M 85% /
    devtmpfs 117.8M 16.0K 117.8M 0% /dev
    none 118.3M 12.0K 118.3M 0% /tmp
    none 118.3M 0 118.3M 0% /media
    none 4.0M 136.0K 3.9M 3% /var/log
    none 118.3M 112.0K 118.2M 0% /var/run
    none 118.3M 0 118.3M 0% /var/lock
    none 118.3M 0 118.3M 0% /var/tmp
    none 118.3M 0 118.3M 0% /sys/fs/cgroup
    tmpfs 118.3M 48.0K 118.2M 0% /run
    /dev/ubi0_1 58.6M 3.4M 52.2M 6% /home
    /dev/ubi0_1 58.6M 3.4M 52.2M 6% /settings
    /dev/ubi0_1 58.6M 3.4M 52.2M 6% /log
    After installation and reboot i have still the wago webinterface. No runtime on Information Tab and the Runtime button from the configuration tab is lost.
    iv try it with firmware 22 and 21. Same problem.
    What can i do?
  • naps - 2024-10-01
    solved: clean browser cache :D
