Flip Flop T. Probably sourcecode issue in codesys
2022-01-09
2022-01-11
  • fabriziobarbato - 2022-01-09
    In image two equivalent scheme of Flip Flop Toggle
    In the upper image:
    Sending pulse on "in1" i can't obtain set of "u1" if i prepare "u1=1" sending pulse return it to 0
    In the lower image:
    Sending pulse on "in1" i can't obtain reset of "u1" if i prepare "u1=0" sending pulse return it to 1
    I hope i'm wronging.
    Last edit: fabriziobarbato 2022-01-09
  • gatto
    gatto - 2022-01-11
    Hi Fabrizio,
    looking just a bit of your code, I think the set of u1 is done from w1 but on the branch below reset is done, so the result is zero.
    if you place a contact false on the branch below, you see the set of u1.
    I leave you an example of flip flop in ladder, hope this can help you.
    Ciao.
    Last edit: gatto 2022-01-11
  • gatto
    gatto - 2022-01-11
    An other ladder example of FF using xor.
    Programming in ST create a FF is very easy 😊
    Ti saluto ancora, ciao
