I am attempting to perform a PLCopenXML import into Codesys. The source of the XML file is a PLCopenXML export from KW.
It is failing to import three objects (Program POUs). The error I see is 'Creation of object 'nameofprogrampou' failed. Reason: The given key was not present in the dictionary.
I am attaching the XML file in a zipped file to this post. The program POUs that fail are:
PRESSURE_DATA
VALVE_CONTROL
VALVE_MONITOR
I am also getting a lot of other messages and warnings and errors in pre-compile, but I am not concerned with those. I am pretty certain these are being generated because there are proprietary function blocks and functions in the KW Export.
PRESSURE_DATA
VALVE_CONTROL
VALVE_MONITOR
MLV_2 3.zip [62.75 KiB]
