Monitor active Codesys connection
2021-12-02
2021-12-09
  • johnhastech
    johnhastech - 2021-12-02
    Hi All,
    I need to monitor an active connection between Codesys(PC) and a PLC. I have tried monitoring active visu clients, but unfortunately this doesn't work. I think this is most likely because the PLC is an embedded system and most importantly doesn't have a display for Visu.
    Monitoring active visu clients on a display works no problem.
    Is there an easy and light weight way of monitoring an active connection between Codesys (PC) and PLC via code? I was really hoping there might be a system variable showing connection state - is there any such variable?
    I have considered whether I can monitor port 1217 just to identify whether packets are being exchanged, but I'm not sure this would be possible?
    Any ideas would be greatly appeciated!
    Best regards,
    John
    • johnhastech
      johnhastech - 2021-12-09
      Any help on this would be greatly appreciated! :D
