Smart meter
2022-05-31
2022-06-06
  • Reinier Geers - 2022-05-31
    I try to read a smart meter with a Windows CE controller. Bought a USB cable. Copy the drivers to the ordner Windows. But after power off the drivers are gone. Knows anyone how to do that? I want the usb as a vurtial com port
  • TimvH
    TimvH - 2022-06-06
    You need to be able to enable the "write" functionality to change the OS. Windows CE is loaded on startup with the default configuration. So you can write to it, but when restarting, it loads the default again. This is done for security and stability reasons. Pleae check with your vendor how to enable changing this.
