I using a frame in the center of my HMI screen to reference a set of other visualizations based on the progression of my process. Pretty standard stuff. For some reason, despite the fact that all of the selected visualizations and the frame itself are the same size, only a couple of the referenced visualizations appear in the frame at the desired size. The others are significantly compressed, as if I never adjusted their screen size to eliminate white space. I can't figure out why this is, since every single property is the same across each referenced visualization.
