I have an embeded ECU which uses Codesys and is used on a vehicle, I would like to set up a remote programming tool for me to be able to update the software remotely (I already have that but right now its a Windows based PC and it not cost effective).
I am thinking of using a raspberry pi as a Client that would be connected to the Ethernet port of my ECU AND to a 3G connexion to the internet. I already have a setup in which I can connect to this RPI but I would like to be able to connect my CodeSys gateway on my PC at the Office to that particular ECU in the field. So I can remote debug the software if needed and update it.
SO my question is, How can I set the route of the gateway if the connexion is not local and not in the same subnet. For me being able to set the route manually would work.
Hello everyone,
I am thinking of using a virtual ethernet adapter with a VPN connection, if that make sense.
