markushunter - 2024-03-20
In our application with CODESYS V3.5 SP19 Patch 5 and the Soft-PLC
Name: CODESYS Control Win V3 x64
Typ: 4096
Version: 3.5.19.50
the application behaves differently when we start the application via Cmp.AppStartApplication(pApp) than when we press the "Start" button in online mode in the IDE.
Unfortunately, it looks like the AppStartApplication() function, which is called in the "StopDone" system event, is not able to restart the fieldbus driver correctly, in our case the EtherNet_IP_Scanner:
Hersteller: 3S - Smart Software Solutions GmbH
Kategorien: EtherNet/IP Scanner
Typ: 100
Version: 4.5.1.0
Bestellnummer: 1
And one EtherNet/IP adapter
Name: FANUC Robot R30iB Plus
Hersteller: FANUC Robotics America
Kategorien: EtherNet/IP Remote Adapter
Typ: 101
Version: Major Revision=16#3, Minor Revision = 16#1
Beschreibung: EtherNet/IP Target imported from EDS File: fanucrobot0301_r30ibp.eds Device: FANUC Robot R30iB Plus
Version Konfiguration 3.5.6.0
The application was cold reset in both cases via CmpApp.AppReset(pApp := pApp, usResetOption := CmpApp.RTS_RESET_COLD.
Does anyone know the difference between the functions or services executed by the "START" button in online mode and Cmp.AppStartApplication()?
Thanks and best regards,
markushunter
