Actually I'm using some picture through image pool in my program.
As it's touch pad screen. When I press the picture I can change state of my variable selected.
But from screen point of view I don't see any effect that shows the state has changed.
So how possible is it to change size ;may be color of the picture or backgroung of it depends state variable.
thank you
thank you
Hi Mawaloc,
If it's a BOOL variable that your changing with a touch then use the Image Switcher which can be found in Toolboxes - Lamps/Switches/Bitmaps.
It lets you assign two bitmaps to a variable, one for OFF and the other for ON.
You can also select if the action should be Toggle (On/Off) or Tap (Momentary)
Good luck
Hi Mawaloc,
i use in such cases the ESC-Button:
https://store.codesys.com/esc-image-button.html
you can download this add-on and example for free in the store.
