cannot compare projects by command line
asivakov
2020-10-16
2020-10-24
  • asivakov - 2020-10-16
    Hello everyone!
    I am using CoDeSys v3.5 SP16. On the help page https://help.codesys.com/webapp/cdscommandline;product=codesys;version=3.5.13.0#switch-compare-project-compare is said that you can use CoDeSys from command line with --compare switch to compare any projects. But for some reason, instead of comparison, CoDeSys just starts as normal. Whatever I tried, move projects on root directory, rename it to simple one-character, several experiments with switch argument syntax - noting worked... If open project manualy and use "project -> compare" - everything works fine. Maybe there is should be some exceptions? Please help me with issue.
    regards
  • TimvH
    TimvH - 2020-10-24
    I tried it, but also cannot get this to work. It just opens CODESYS, but not projects...
    I used:
    CODESYS --profile="CODESYS V3.5 SP16 Patch 1" --compare="C:\test\Project1.project""C:\test\Project2.project"
